Disables external Telnet services on the system.
Enabled.
You must be logged in as an administrator to enable or disable Telnet.
Telnet sessions between the nodes of a stack are not affected by this command.
With administrator privilege, the following command disables external Telnet services on the switch:
disable telnet
